Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
4. Schritt
Use the pointed tip of a spudger to disconnect the microphone cable connector from its socket on the logic board. Use the pointed tip of the spudger to disconnect the GPS antenna cable, directly to the right of the microphone cable connector. Use the pointed tip of the spudger to disconnect the GPS antenna cable, directly to the right of the microphone cable connector.
  • Use the pointed tip of a spudger to disconnect the microphone cable connector from its socket on the logic board.
  • Use the pointed tip of the spudger to disconnect the GPS antenna cable, directly to the right of the microphone cable connector.
Hier Übersetzung einfügen
