Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
10. Schritt
Use the flat end of a spudger to gently fold the primary cellular antenna interconnect cable bracket up and out of the way. The small, S-shaped interconnect cable remains attached to the bracket via a press connector on the underside of the bracket. If it disconnects accidentally, reconnect it by pressing it into place.
  • Use the flat end of a spudger to gently fold the primary cellular antenna interconnect cable bracket up and out of the way.
  • The small, S-shaped interconnect cable remains attached to the bracket via a press connector on the underside of the bracket. If it disconnects accidentally, reconnect it by pressing it into place.
Hier Übersetzung einfügen
