Englisch
Deutsch
3. Schritt
Push metal bracket away from battery connector. Use a spudger to push the battery connection straight up. If you pry too hard, or attempt to disconnect the battery with the metal bracket still in place, you risk pulling the connector off of the motherboard.
Disconnect the battery
  • Push metal bracket away from battery connector.
  • Use a spudger to push the battery connection straight up.
  • If you pry too hard, or attempt to disconnect the battery with the metal bracket still in place, you risk pulling the connector off of the motherboard.
  • Make sure the computer is powered off before removing the battery.
Hier Übersetzung einfügen
