Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 29
Slide your pick across the width of the iPhone to separate all the remaining areas of the Lightning connector assembly from the rear case. Slide your pick across the width of the iPhone to separate all the remaining areas of the Lightning connector assembly from the rear case. Slide your pick across the width of the iPhone to separate all the remaining areas of the Lightning connector assembly from the rear case.
  • Slide your pick across the width of the iPhone to separate all the remaining areas of the Lightning connector assembly from the rear case.
Schiebe das Plektrum entlang der Breite des iPhones und trenne die ganze Lightning Connector Einheit vom rückwärtigen Gehäuse ab.
