Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 31 übersetzen
Schritt 31
A rubber gasket on the bottom of the Lightning connector protects your iPhone from liquid and dust intrusion. If you are installing a new Lightning connector assembly, you may need to carefully remove and transfer the gasket to the new part. The small adhesive patch on the bottom of each microphone also protects your iPhone from liquid and dust intrusion. For best results, replace the two adhesive patches before installing your Lightning connector assembly. Important: During installation, correctly position your new Lightning connector assembly so that the cutouts in the cable are exactly centered around the four screw bosses in the rear case. Otherwise, the flex cable will be misaligned and you won't be able to reconnect it to its socket on the logic board.
  • A rubber gasket on the bottom of the Lightning connector protects your iPhone from liquid and dust intrusion. If you are installing a new Lightning connector assembly, you may need to carefully remove and transfer the gasket to the new part.
  • The small adhesive patch on the bottom of each microphone also protects your iPhone from liquid and dust intrusion. For best results, replace the two adhesive patches before installing your Lightning connector assembly.
  • Important: During installation, correctly position your new Lightning connector assembly so that the cutouts in the cable are exactly centered around the four screw bosses in the rear case. Otherwise, the flex cable will be misaligned and you won't be able to reconnect it to its socket on the logic board.
Eine Gummidichtung unten am Lightning Connector schützt das iPhone gegen das Eindringen von Feuchtigkeit und Staub. Wenn du einen neuen Lightning Connector einbauen willst, musst du diese Dichtung sorgfältig ausbauen und auf dein neues Ersatzteil übertragen.
Das kleine Klebeband unten an jedem Mikrofon schützt das iPhone ebenfalls vor dem Eindringen von Staub und Feuchtigkeit. Um möglichst gute Ergebnisse zu erzielen, solltest du diese beiden Aufkleber vor dem Einbau der Lightning Connector Einheit austauschen.
Wichtig: Baue die Lightning Connector Einheit so ein, dass sich die vier Schraubdome im rückwärtigen Gehäuse genau mittig in den Ausschnitten im Kabel befinden. Ansonsten sitzt das Flexkabel nicht richtig und du kannst es nicht mit seinem Anschluss auf dem Logic Board verbinden.
