Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 12 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Remove four Phillips (JIS) screws securing the lower display cable bracket to the logic board, of the following lengths: Two 1.3 mm screws
Battery Disconnection
  • Remove four Phillips (JIS) screws securing the lower display cable bracket to the logic board, of the following lengths:
  • Two 1.3 mm screws
  • One 1.4 mm screw
  • One 2.7 mm screw
  • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
Entferne die vier Kreuzschlitzschrauben (JIS) auf dem Logic Board, welche die Halterung am unteren Displaykabel befestigen :
Zwei 1,3 mm Schrauben
Eine 1,4 mm Schraube
Eine 2,7 mm Schraube
[title] Battery Disconnection
[* black] Remove the four Phillips (JIS) screws securing the lower display cable bracket to the logic boardboard, of the following lengths:
[* red] Two 1.3 mm screws
[* orange] One 1.4 mm screw
[* yellow] One 2.7 mm screw
[* icon_reminder] Throughout this guide, [product|IF145-167-4|keep careful track of your screws] so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
