Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 12 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Remove four Phillips screws securing the lower display cable bracket to the logic board, of the following lengths: Two 1.3 mm screws
  • Remove four Phillips screws securing the lower display cable bracket to the logic board, of the following lengths:
    • Two 1.3 mm screws
    • Two 2.8 mm screws
  • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  • Remove the bracket.
Entferne die vier Kreuzschlitzschrauben, die die Halterung des unteren Displaykabels am Logic Board befestigen.
Zwei 1,3 mm Schrauben.
Zwei 2,8 mm Schrauben.
Entferne die Halterung.
[* black] Remove the four Phillips screws securing the lower display cable bracket to the logic boardboard, of the following lengths:
[* red] Two 1.3 mm screws
[* orange] Two 2.8 mm screws
[* icon_reminder] Throughout this guide, [product|IF145-167-4|keep careful track of your screws] so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
[* black] Remove the bracket.
