Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 4
There is a rubber grommet that keep moisture away from the inside of the board. There IS also this sillica pack inside the camera if moisture ever breach in. The base is fixed to the feet using a single Phillips #1 screw
Outer casing
  • There is a rubber grommet that keep moisture away from the inside of the board.
  • There IS also this sillica pack inside the camera if moisture ever breach in.
  • The base is fixed to the feet using a single Phillips #1 screw
  • In order to separate the camera from the feet, you will need to undo the connector. The wires are thin so be careful.
Hier Übersetzung einfügen
