Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 12
Insert an opening pick between the power and volume button circuit board and the frame. Slide the pick behind the circuit board, across the whole board, to separate it from the adhesive securing it to the frame. If it's difficult to slide the pick behind the circuit board, try heating the circuit board to soften its adhesive.
  • Insert an opening pick between the power and volume button circuit board and the frame.
  • Slide the pick behind the circuit board, across the whole board, to separate it from the adhesive securing it to the frame.
  • If it's difficult to slide the pick behind the circuit board, try heating the circuit board to soften its adhesive.
Führe ein Opening Pick zwischen die Platine für Power-Button und Lautstärkeregler und dem Rahmen.
Schiebe das Opening Pick hinter der gesamten Platine entlang, um diese vom Kleber zu lösen, der sie am Rahmen befestigt.
Falls es zu schwierig ist, das Pick hinter die Platine zu schieben, versuche diese zu erhitzen, um den Kleber zu erweichen.
