Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 10 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 7 übersetzen
Step 7
Remove the lower case. To reinstall the lower case: Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
  • Remove the lower case.
  • To reinstall the lower case:
  • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
  • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
Entferne das untere Gehäuse.
[title] Remove the lower case
[* black] Remove the lower case.
[* icon_reminder] To reinstall the lower case:
[* red] [https://d3nevzfk7ii3be.cloudfront.net/igi/BIcTYrImhMkTbsEJ.huge|Set it in place|new_window=true] and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
[* orange] When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
