Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 8 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 7 übersetzen
Step 7
Use a spudger to gently lift the battery power connector, disconnecting the battery. Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
Disconnect the battery
  • Use a spudger to gently lift the battery power connector, disconnecting the battery.
  • Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
Hebe den Akkustromstecker vorsichtig mit einem Spudger an, und trenne so den Akku ab.
Hebe den Stecker so hoch, dass er von seinem Anschluss getrennt bleibt. Falls er sich während der Reparatur versehentlich wieder verbindet, könnte das dein MAcBook Pro beschädigen.
[title] Disconnect the battery
[* black] Use a spudger to gently lift the battery power connector, disconnecting the battery.
[* black] Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
