Englisch
Deutsch
3. Schritt
Your distributor should now look the same as the one pictured to the left. Take note of the notch on the body of the distributor opposite the vacuum advance can: this is where the new leads exit.
  • Your distributor should now look the same as the one pictured to the left.
  • Take note of the notch on the body of the distributor opposite the vacuum advance can: this is where the new leads exit.
  • Place the new breaker plate back on the distributor, so that the threads face up, and the advance pin slides into the vacuum advance shaft.
  • Place the ignition module on the threaded studs as shown.
  • Set one end of the ground strap on the stud nearest to the notch and loosely put on the two locking nuts.
Hier Übersetzung einfügen
