Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Deutsch
7. Schritt
Carefully disconnect the three antenna coax cables by prying them straight up from the logic board. Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it. To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
  • Carefully disconnect the three antenna coax cables by prying them straight up from the logic board.
  • Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
  • To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
Trenne die drei Koaxialkabel mithilfe einer Pinzette von der Hauptplatine ab.
[* black] Use a pair of tweezers toCarefully disconnect the three antenna coax cables by prying them '''straight up''' from the mainlogic board.
[* black] Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
[* icon_reminder] To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
