Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 12 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2 übersetzen
2. Schritt
Remove the shield plate from the device. A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. Use our thermal paste guide to remove the old thermal compound and replace it with an appropriate, thick compound such as K5 Pro. A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. Use our thermal paste guide to remove the old thermal compound and replace it with an appropriate, thick compound such as K5 Pro.
  • Remove the shield plate from the device.
  • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. Use our thermal paste guide to remove the old thermal compound and replace it with an appropriate, thick compound such as K5 Pro.
Entferne das Abschirmblech vom Gerät.
[* black] Remove the shield plate from the device.
[* icon_reminder] A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. Use our [guide|744|thermal paste guide|new_window=true] to remove the old thermal compound and replace it with an appropriate, thick compound such as [https://www.amazon.com/viscous-thermal-paste-replacement-Aspire/dp/B01GQ7TFTM/ref=sr_1_4?ie=UTF8&qid=1508975365&sr=8-4&keywords=k5+pro&tag=ifixitam-20|K5 Pro|new_window=true].
