Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 4
Use a spudger to gently pry the battery connector straight up from its socket on the motherboard. This will keep the Joy-Con from powering on during the repair. Be extremely careful as you pry up the battery connector. If it doesn't come up with the spudger, try gently pulling on the cables to disconnect it.
  • Use a spudger to gently pry the battery connector straight up from its socket on the motherboard. This will keep the Joy-Con from powering on during the repair.
  • Be extremely careful as you pry up the battery connector. If it doesn't come up with the spudger, try gently pulling on the cables to disconnect it.
  • During reassembly, press the connector straight down into its socket on the board to reconnect the battery.
Benutze einen Spudger, um den Akkustecker aus seinem Anschluss auf dem Motherboard zu lösen. Dies verhindert das Einschalten des Joy-Con während der Reparatur.
Pass auf das Kabel des Vibrationsmotors auf. Es liegt direkt neben dem Akkukabel. Wenn das Sich das Akkukabel nicht lösen lässt, ziehe vorsichtig an den Kabeln um es zu lösen.
