Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 3
Remove the nut and the cover of the fusebox. Use the inside of the fusebox cover to determine which fuses you need to check. Locate the fuse grabber. The fuse grabber is located near the front of the fusebox. Remove the fuse grabber from its holder.
  • Remove the nut and the cover of the fusebox. Use the inside of the fusebox cover to determine which fuses you need to check.
  • Locate the fuse grabber. The fuse grabber is located near the front of the fusebox.
  • Remove the fuse grabber from its holder.
Hier Übersetzung einfügen
