Englisch
Deutsch
Step 7
Before applying any adhesive, make sure your replacement part fits, and that all connectors will connect without putting too much stress on their cables. If it is safe to do so, power on your device and verify that everything functions correctly. If everything works, power off the device and continue. If anything does not function as expected, visit the Answers Forum for troubleshooting advice. With the device powered off, apply the correct adhesive shape for your repair.
Application and Installation
  • Before applying any adhesive, make sure your replacement part fits, and that all connectors will connect without putting too much stress on their cables. If it is safe to do so, power on your device and verify that everything functions correctly. If everything works, power off the device and continue.
  • If anything does not function as expected, visit the Answers Forum for troubleshooting advice.
  • With the device powered off, apply the correct adhesive shape for your repair.
  • Avoid applying adhesive over ribbon cables, or delicate surfaces like NFC or wireless charging coils.
  • When applying adhesive strips, make sure to apply one end first, then use a finger or the flat end of a spudger to smooth the rest of the strip as you lay it down, squeezing out any air bubbles.
  • Use a pair of tweezers to peel the backing off the adhesive.
Bevor du irgendwelche Klebestreifen anbringst, musst du zunächst sicher sein, dass das Ersatzteil passt, und dass alle Stecker verbunden werden können, ohne ihre Kabel zu belasten. Wenn das in Ordnung ist, schalte dein Gerät ein, um zu testen , dass alles gut funktioniert. Wenn das der Fall ist, kannst du es wieder ausschalten und weitermachen.
Falls irgendetwas nicht so funktioniert wie es sollte, dann findest du im Antwortenforum Hilfe bei der Fehlersuche.
Wenn dein Gerät wieder ausgeschaltet ist, kannst du die entsprechend passenden Klebestreifen anbringen.
Vermeide es, Klebestreifen über Flachbandkabel oder empfindliche Oberflächen wie NFC oder kabellose Ladespulen zu kleben.
Achte beim Anbringen des Klebestreifens darauf, zuerst ein Ende anzukleben, und dann deinen Finger oder das flache Ende eines Spudgers zu benutzten, um den Rest des Klebestreifen flach zu streichen während du ihn richtig positionierst, um Luftblasen unter dem Klebestreifen zu vermeiden.
Ziehe die Schutzfolie mit einer Pinzette vom Klebestreifen ab.
