Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
8. Schritt
If you successfully removed the entire ambient light sensor, as shown in the first photo, continue to the next step below. If the white diffuser strip detached and remains embedded in the display, as shown in the second photo, you will need to carefully lever it out along the top edge using a thin blade or pry tool. Re-applying heat first may make this task a bit easier. During reassembly, install the diffuser into the display first, making sure it faces the right direction (the front-facing side is shown in the first image, and the rear-facing side is shown in the third).
  • If you successfully removed the entire ambient light sensor, as shown in the first photo, continue to the next step below.
  • If the white diffuser strip detached and remains embedded in the display, as shown in the second photo, you will need to carefully lever it out along the top edge using a thin blade or pry tool. Re-applying heat first may make this task a bit easier.
  • During reassembly, install the diffuser into the display first, making sure it faces the right direction (the front-facing side is shown in the first image, and the rear-facing side is shown in the third).
  • Then, set the ambient light sensor on top of the diffuser. You will need to hold the sensor in position while installing the screws securing the earpiece/sensor assembly. Once the screws are tightened, the sensor will stay in place and work normally.
Wenn du den ganzen Umgebungslichtsensor wie im ersten Bild entfernt hast, dann fahre mit dem Schritt weiter unten fort.
Wenn aber der weiße Verteilerstreifen im Display bleibt wie im zweiten Bild, musst du ihn sorgfältig an der Oberkante mit einer Rasierklinge oder einem geeigneten Hebelwerkzeug herausheblen. Es ist leichter, wenn du dazu den Bereich erst nochmal erwärmst.
Setze beim Zusammenbau diesen Verteiler zuerst in das Display ein. Achte dabei darauf, dass er richtig positioniert ist (die Vorderseite ist im ersten Bild zu sehen, die Rückseite im dritten).
Setze dann den Umgebungslichtsensor auf den Verteiler auf. Du musst den Sensor in dieser Lage festhalten, während du die Schrauben einsetzt, mit denen die Ohrhörer-Lautsprecher/Sensoreinheit befestigt wird. Wenn die Schrauben festgedreht sind, dann hält auch der Sensor fest und funktioniert ganz normal.
