Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2 übersetzen
2. Schritt
Using your fingers, pull the small plastic tab away from the circuit board/faceplate sub-assembly. Rotate the faceplate away from the circuit board. Gently remove the faceplate from the circuit board, taking care to not break the small plastic tab on the other side of the sub-assembly.
  • Using your fingers, pull the small plastic tab away from the circuit board/faceplate sub-assembly.
  • Rotate the faceplate away from the circuit board.
  • Gently remove the faceplate from the circuit board, taking care to not break the small plastic tab on the other side of the sub-assembly.
Hier Übersetzung einfügen
