Englisch
Deutsch
Schritt 3 übersetzen
3. Schritt
Pull the ribbon connector out of its slot using one hand and another hand on the base of the charging assembly. Make sure the gray pieces are in the “open” position when you reassemble the ribbon connector or the connector will not go into its slot.
  • Pull the ribbon connector out of its slot using one hand and another hand on the base of the charging assembly.
  • Make sure the gray pieces are in the “open” position when you reassemble the ribbon connector or the connector will not go into its slot.
Hier Übersetzung einfügen
