Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Remove either of the two 0.2 mm axle screws by using a hex bit 4.0 by turning clockwise. The two screws are the same thread so find the screw that has the least torque. Only that screw will be able to removed in this step.
  • Remove either of the two 0.2 mm axle screws by using a hex bit 4.0 by turning clockwise.
  • The two screws are the same thread so find the screw that has the least torque. Only that screw will be able to removed in this step.
  • Turn the hex bit 4.0 counterclockwise to reassemble the axle screws.
Hier Übersetzung einfügen
