Zum Hauptinhalt wechseln
Englisch
Deutsch
6. Schritt
Remove the plate covering the from camera. BEWARE! The front cam connector may be attached to the plate, lift it up carefully, removing the connector and then remove the plate to the right. Remove the plate covering the main camera connector and disconnect it. Carefully! Pry from beneath the board gently upwards where indicated, then gently pull to the left/downwards in and upwards direction.
Removing the main board
  • Remove the plate covering the from camera. BEWARE! The front cam connector may be attached to the plate, lift it up carefully, removing the connector and then remove the plate to the right.
  • Remove the plate covering the main camera connector and disconnect it.
  • Carefully! Pry from beneath the board gently upwards where indicated, then gently pull to the left/downwards in and upwards direction.
Hier Übersetzung einfügen
