Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diesen Schritt beinhaltet.
Englisch
Deutsch
Schritt 3 übersetzen
3. Schritt
Turn down the squared tabs on the brushbar so that they face outward. Use a screwdriver to pry the belt up from the brushbar.
  • Turn down the squared tabs on the brushbar so that they face outward.
  • Use a screwdriver to pry the belt up from the brushbar.
  • Be careful not to cut the belt with the screwdriver.
  • While holding the belt, pull the brushbar to the left and remove it from the vacuum.
  • You can let go of the belt when it's free from the brushbar. The belt will not retract into the vacuum.
  • During reassembly, insert the brushbar with the tabs facing outward, then rotate the tabs up to lock the brushbar in place.
Hier Übersetzung einfügen
