Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Englisch
Deutsch
Schritt 4
Depending on if your lamp uses a press or screw socket, this may not be reusable. After removing the plastic cover and switch, remove the bulb socket. You will need different tools for screw and push wire sockets.
Remove the bulb socket
  • Depending on if your lamp uses a press or screw socket, this may not be reusable.
  • After removing the plastic cover and switch, remove the bulb socket. You will need different tools for screw and push wire sockets.
  • Discard or recycle any components you do not want to reuse.
Hier Übersetzung einfügen
