Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 2 übersetzen
Schritt 2
Lift the keyboard to expose the ribbon connector and lean it against the computer screen to keep the ribbon intact. If the ribbon is broken, the keyboard is permanently unusable and needs to be replaced Use the plastic opening tool to gently pry the connector up from the motherboard.
  • Lift the keyboard to expose the ribbon connector and lean it against the computer screen to keep the ribbon intact.
  • If the ribbon is broken, the keyboard is permanently unusable and needs to be replaced
  • Use the plastic opening tool to gently pry the connector up from the motherboard.
  • You can now safely remove the keyboard.
Hier Übersetzung einfügen
