Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
1. Schritt
Begin by removing the two black 16 mm Phillips #0 screws. The screws can be identified by the two notches next to each screw.  One (marked in red) is near the battery lock and the other (not pictured) is next to the Wi-Fi cover. Push up the bottom of the keyboard by poking your finger through the hole to the right of the yellow bios battery. You will feel slight resistance.
  • Begin by removing the two black 16 mm Phillips #0 screws. The screws can be identified by the two notches next to each screw. One (marked in red) is near the battery lock and the other (not pictured) is next to the Wi-Fi cover.
  • Push up the bottom of the keyboard by poking your finger through the hole to the right of the yellow bios battery. You will feel slight resistance.
  • Be sure to not lift the keyboard too far. It is still attached to the computer with a ribbon connector.
Hier Übersetzung einfügen
