Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2 übersetzen
2. Schritt
Lift the keyboard to expose the ribbon connector and lean it against the computer screen to keep the ribbon intact. If the ribbon is broken, the keyboard is permanently unusable and needs to be replaced Use the plastic opening tool to gently pry the connector up from the motherboard.
  • Lift the keyboard to expose the ribbon connector and lean it against the computer screen to keep the ribbon intact.
  • If the ribbon is broken, the keyboard is permanently unusable and needs to be replaced
  • Use the plastic opening tool to gently pry the connector up from the motherboard.
  • You can now safely remove the keyboard.
Hier Übersetzung einfügen
