Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 3 übersetzen
3. Schritt
Using the plastic opening tool, gently lift the white connector out of its socket on the motherboard. Before installing the new fan, remove all remnants of thermal compound from the top of the CPU.  Warning—the stuff is hard to clean off clothing.  Spread a small amount of fresh heat sink compound (DC-340 or equivalent) on the top of the CPU to form a thin coat.  Be sure the mating fan heat sink is clean.
  • Using the plastic opening tool, gently lift the white connector out of its socket on the motherboard.
  • Before installing the new fan, remove all remnants of thermal compound from the top of the CPU. Warning—the stuff is hard to clean off clothing. Spread a small amount of fresh heat sink compound (DC-340 or equivalent) on the top of the CPU to form a thin coat. Be sure the mating fan heat sink is clean.
  • Follow iFixit's guide for [Ungültiger Anleitungslink] for a detailed explanation.
Hier Übersetzung einfügen
