Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Locate the transfer case in the center of the undercarriage of your Dodge. Position yourself under the drivers side seat and look upwards toward the front left tire. Locate the fill plug on the transfer case. and remove it using the 10 mm hex driver. The fill plug is the upper steel  plug just to the left of the rear output of the transfer case.
  • Locate the transfer case in the center of the undercarriage of your Dodge. Position yourself under the drivers side seat and look upwards toward the front left tire.
  • Locate the fill plug on the transfer case. and remove it using the 10 mm hex driver. The fill plug is the upper steel plug just to the left of the rear output of the transfer case.
  • No oil will drain after the filler plug is removed.
Hier Übersetzung einfügen
