Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 7
Push the stopper down on the loaded syringe until it is almost empty. Do not empty the bottom syringe completely, as this will cause air to be injected into the brake lines, causing malfunctions once you try to use your bike.
  • Push the stopper down on the loaded syringe until it is almost empty.
  • Do not empty the bottom syringe completely, as this will cause air to be injected into the brake lines, causing malfunctions once you try to use your bike.
  • The empty syringe will fill with the excess hydraulic fluid.
  • Always push the fluid through the system starting from the lowest point. In this case it is the rear brakes.
Hier Übersetzung einfügen
