Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 8
The display assembly can be pried out of the rear case with some difficulty. There are lots of small fragile clips and stubborn adhesive around the edges. It's quite difficult to reach all the way under the display, so you risk separating the various frames from the screen.
  • The display assembly can be pried out of the rear case with some difficulty. There are lots of small fragile clips and stubborn adhesive around the edges.
  • It's quite difficult to reach all the way under the display, so you risk separating the various frames from the screen.
  • The initial point of entry seems to be the hinges at the bottom, but the outside edges and top must be freed before the lower central portion, which isn't immediately evident.
  • After cutting through all the adhesive and nearly bending the sensor assembly board in half, the display can be lifted up, but not removed.
  • The thin sensor board is adhered to the display and to the rear case, so display removal pulls it between the two. On the other hand, slicing that adhesive runs the chance of damaging the cameras.
Hier Übersetzung einfügen
