Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 7 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Step 3
Hold onto your iPhone securely and close the handle of the iSclack to slightly separate the screen from the rear case of the phone. Don't try to completely separate the screen; a small opening along the bottom edge is all you need. Insert an opening pick into the gap under the display on the lower edge of the iPhone.
  • Hold onto your iPhone securely and close the handle of the iSclack to slightly separate the screen from the rear case of the phone.
  • Don't try to completely separate the screen; a small opening along the bottom edge is all you need.
  • Insert an opening pick into the gap under the display on the lower edge of the iPhone.
  • Skip the next two steps.
Halte dein iPhone gut fest und drücke den Griff des iSclack zusammen, um das Display ein wenig vom Rückgehäuse zu lösen.
Versuche nicht, das Display völlig abzulösen, eine kleine Öffnung an der Unterkante ist ausreichend.
Setze ein Plektrum in den Spalt unter dem Display an der Unterkante des iPhones.
Überspringe die nächsten beiden Schritte und mache bei Schritt 7 weiter.
[* black] Hold onto your iPhone securely and close the handle of the iSclack to slightly separate the screen from the rear case of the phone.
[* icon_caution] Don't try to completely separate the screen; a small opening along the bottom edge is all you need.
[* black] Insert an opening pick into the gap under the display on the lower edge of the iPhone.
[* black] '''Skip the next two steps and continue to step 7steps.'''
