Zum Hauptinhalt wechseln
Englisch
Deutsch
4. Schritt
In the following steps, you'll pull each tab to slowly stretch out the adhesive underneath the battery. This special stretch-release adhesive loses its tack when stretched and then comes out in your hand, allowing you to lift out the battery with ease. If the strips break, don't panic! They don't always work as intended. Keep reading for some additional steps for removing broken strips. To increase your odds of success:
  • In the following steps, you'll pull each tab to slowly stretch out the adhesive underneath the battery. This special stretch-release adhesive loses its tack when stretched and then comes out in your hand, allowing you to lift out the battery with ease.
  • If the strips break, don't panic! They don't always work as intended. Keep reading for some additional steps for removing broken strips.
  • To increase your odds of success:
  • Don't press down on the battery. Hold the iPhone firmly by its sides.
  • Keep the strips flat and unwrinkled as you pull.
  • Pull very slowly, giving the strip time to stretch and separate. It takes around 15-30 seconds of stretching to remove each strip.
  • Pull at a low angle so the strip doesn't snag along the bottom edge of the battery.
  • If a strip does break off underneath the battery and cannot be retrieved, move on to the other strips and then continue with the additional steps below.
In den nächsten Schritten wird jeder Klebestreifen unter dem Akku langsam gedehnt. Wenn diese speziellen elastischen Klebestreifen gedehnt werden, lösen sie sich ab, sodass der Akku problemlos herausgehoben werden kann.
Nur keine Panik, falls einer der Klebestreifen reißt! Sie funktionieren leider nicht immer so wie sie sollten. Lies weiter, um herauszufinden, wie du einen abgerissenen Klebestreifen herausholen kannst.
Hier sind ein paar Tipps, um die Klebestreifen möglichst erfolgreich zu entfernen:
Drücke den Akku nicht herunter. Halte das iPhone gut an den Seiten fest.
Halte die Streifen beim Ziehen glatt und faltenlos.
Ziehe sehr langsam, sodass sich der Streifen dehnen und ablösen kann. Zum Entfernen jeden Streifens werden etwa 15-30 Sekunden benötigt.
Ziehe in einem flachen Winkel, sodass der Streifen nicht an der Unterkante des Akkus hängen bleibt.
Falls ein Streifen unter dem Akku reißt und nicht mehr herausgeholt werden kann, dann mache mit den anderen Streifen weiter und folge dann den unten beschriebenen Schritten.
