Zum Hauptinhalt wechseln
Englisch
Deutsch
10. Schritt
If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery. Heat the iPhone until the rear case is slightly too hot to comfortably touch. Don't overheat the iPhone, or you may accidentally ignite the battery. Flip the iPhone back over and thread a strong piece of string (such as dental floss or a length of thin guitar string) underneath the battery.
  • If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery.
  • Heat the iPhone until the rear case is slightly too hot to comfortably touch. Don't overheat the iPhone, or you may accidentally ignite the battery.
  • Flip the iPhone back over and thread a strong piece of string (such as dental floss or a length of thin guitar string) underneath the battery.
  • Wear gloves to protect your fingers, or wrap each end of the string around a tool.
  • Pull the string from side to side in a sawing motion to separate the adhesive. This can take some time since the adhesive is slow to deform, but with patience it will come free. Do not deform or damage the battery.
  • Start from the top or bottom edge of the battery, and pull toward the middle. Don't pull the string through the middle third of the battery, or you may damage the ribbon cables or the wireless charging coil directly underneath.
  • If you choose to use pry tools to lift the battery out of the iPhone, use extreme caution or you may damage the ribbon cables or the wireless charging coil directly underneath the battery.
Wenn einer der Klebestreifen gerissen ist, und der Akku im Rückgehäuse festklebt, dann bereite einen iOpener vor oder benutze einen Fön, um das Rückgehäuse direkt hinter dem Akku zu erhitzen.
Erhitze das iPhone bis es gerade so warm ist, dass es beim Anfassen unangenehm ist. Überhitze das iPhone nicht, da du sonst versehentlich den Akku entzünden könntest.
Drehe das iPhone wieder um und fädle ein Stück starken Fadens (wie zum Beispiel Zahnseide oder eine dünne Gitarrensaite) unter den Akku.
Trage Handschuhe, um deine Finger zu schützen, oder wickle den Faden um ein Werkzeug.
Ziehe den Faden mit einer Sägebewegung hin und her, um den Kleber zu durchtrennen. Das kann eine Weile dauern, da sich der Kleber nur langsam verformt, aber mit etwas Geduld ist es zu schaffen. Achte darauf, den Akku nicht zu verformen oder zu beschädigen.
Beginne an der Ober- oder der Unterkante des Akkus und arbeite dich zur Mitte vor. Ziehe den Faden nicht durch das mittlere Drittel des Akkus, da du sonst die Flachbandkabel bzw. die kabellose Ladespule direkt darunter beschädigen könntest.
Wenn du Hebelwerkzeuge benutzt, um den Akku hochzuheben, dann sei extrem vorsichtig, um zu vermeiden, dass die Flachbandkabel oder die kabellose Ladespule direkt unter dem Akku beschädigt werden.
