Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 3
Use the opening pick to slice through the glass panel's perimeter adhesive. As you slice the adhesive, make sure that you are slicing above the NFC pad. If the slicing becomes hard, reapply heat to the panel.
  • Use the opening pick to slice through the glass panel's perimeter adhesive.
  • As you slice the adhesive, make sure that you are slicing above the NFC pad.
  • If the slicing becomes hard, reapply heat to the panel.
Trenne mit dem Plektrum den Kleber rings um den Rand der Glasscheibe auf.
Wenn das Auftrennen schwergängig wird, dann erwärme erneut.
[* black] Use the opening pick to slice through the glass panel's perimeter adhesive.
[* icon_note] As you slice the adhesive, make sure that you are slicing above the [https://d3nevzfk7ii3be.cloudfront.net/igi/AbXqTfBTiXBfoWTT.huge|NFC pad|new_window=true].
[* black] If the slicing becomes hard, reapply heat to the panel.
