Zum Hauptinhalt wechseln
Englisch
Deutsch
5. Schritt
Oil will begin flowing as soon as you unscrew the filter.  Be sure to catch all of the oil in the drain pan. Loosen the oil filter by twisting counter-clockwise. It may be easier to access the oil filter from the top-side of the engine. If it is too difficult to twist by hand, use an oil filter wrench to loosen it.
  • Oil will begin flowing as soon as you unscrew the filter. Be sure to catch all of the oil in the drain pan.
  • Loosen the oil filter by twisting counter-clockwise. It may be easier to access the oil filter from the top-side of the engine.
  • If it is too difficult to twist by hand, use an oil filter wrench to loosen it.
  • Place the removed oil filter in the oil pan.
Das Öl beginnt rauszufließen, sobald du den Filter losdrehst. Achte darauf, das komplette Öl in der Wanne aufzufangen.
Löse den Filter durch Drehung im Gegenuhrzeigersinn. Eventuell ist der Filter von oben her besser erreichbar.
Falls das Drehen von Hand zu schwer ist nimm einen beliebigen Filterschlüssel zu Hilfe.
Stelle den entfernten Filter in die Wanne.
