Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
2. Schritt
Gently slide the flat end of a spudger underneath the piece of foam tape covering the button ribbon cable. Run the spudger along the full length of the tape to disconnect it from the rear case. Run the spudger along the full length of the tape to disconnect it from the rear case.
  • Gently slide the flat end of a spudger underneath the piece of foam tape covering the button ribbon cable.
  • Run the spudger along the full length of the tape to disconnect it from the rear case.
Hier Übersetzung einfügen
