Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 7
After the speaker has been removed, you should now be able to see the battery underneath.
  • After the speaker has been removed, you should now be able to see the battery underneath.
  • The next step is to remove the motherboard from the casing. To do this, first make sure the necessary connectors have been disconnected and the two silver screws have also been removed as mentioned in step 5.
  • Apply gentle pressure to the edges of the motherboard and gently pry it loose from the casing. You should feel a small amount of resistance as there is a small bit of adhesive present holding the motherboard in place.
Hier Übersetzung einfügen
