Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 9
After the battery has been removed, the clear tape on the old battery needs to be removed. Do this by carefully unwrapping the clear yellow tape from the battery. Any excessive force will damage the battery.
  • After the battery has been removed, the clear tape on the old battery needs to be removed. Do this by carefully unwrapping the clear yellow tape from the battery. Any excessive force will damage the battery.
  • Next, de-solder the old battery circuit from the old battery. You will need this circuit, so be careful not to damage it!
  • If you heat up the battery too hot, it will explode! You must be quick when de-soldering and soldering to the battery!
  • De-solder the battery circuit that comes with the new cell, and solder the battery circuit from the old ring battery to the new battery. This will convert your new cell to a cell compatible with the Ring's charging circuitry.
  • Make sure to observe polarities. The solder pad with the red wire next to it goes to the '+'poll on the battery, and the solder pad with the black wire next to it goes to the '-' poll on the battery.
Hier Übersetzung einfügen
