Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 5 übersetzen
5. Schritt
Locate the drain valve on your water heater, which is placed at the bottom of the tank. Yours may look different than what's pictured. It most commonly looks like a traditional garden hose spigot There may already be a drain hose attached to the drain valve that leads to a nearby drain. If not, you can connect a garden hose to the drain valve and drain the water to a nearby floor drain or sink. To begin draining your water heater, open up the drain valve by rotating the knob counter-clockwise.
  • Locate the drain valve on your water heater, which is placed at the bottom of the tank. Yours may look different than what's pictured. It most commonly looks like a traditional garden hose spigot
  • There may already be a drain hose attached to the drain valve that leads to a nearby drain. If not, you can connect a garden hose to the drain valve and drain the water to a nearby floor drain or sink.
  • To begin draining your water heater, open up the drain valve by rotating the knob counter-clockwise.
  • If you're just performing maintenance, simply let the water drain for five minutes or so to flush out any sediment buildup.
Hier Übersetzung einfügen
