Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 3
Use a Phillips #4 screwdriver or driver with the Phillips #4 head to unscrew the two 0.6 mm diameter brass screws from the lamp's housing. For the lower screw, ensure it remains in the hole in the lamp assembly and it does not fall into the projector.  If it falls in the projector, use a magnetized screw bit or a small magnet to pick it up and remove it. For the lower screw, ensure it remains in the hole in the lamp assembly and it does not fall into the projector.  If it falls in the projector, use a magnetized screw bit or a small magnet to pick it up and remove it.
Unscrew the Lamp from the Projector
  • Use a Phillips #4 screwdriver or driver with the Phillips #4 head to unscrew the two 0.6 mm diameter brass screws from the lamp's housing.
  • For the lower screw, ensure it remains in the hole in the lamp assembly and it does not fall into the projector. If it falls in the projector, use a magnetized screw bit or a small magnet to pick it up and remove it.
Hier Übersetzung einfügen
