Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Measure top and bottom of damaged section. When replacing a corner bead, you must measure at least 1.5 inches from the corner. Use a straight edge between the the top and bottom and draw a straight-line connecting the marking.
  • Measure top and bottom of damaged section.
  • When replacing a corner bead, you must measure at least 1.5 inches from the corner.
  • Use a straight edge between the the top and bottom and draw a straight-line connecting the marking.
  • You can even use the putty knife if the damaged section is not too long.
  • Mark with a pencil, or cut lightly with utility knife.
  • Use caution when using the utility knife as the blade is very sharp and may cause an injury.
Hier Übersetzung einfügen
