Zum Hauptinhalt wechseln
Englisch
Deutsch
21. Schritt
I can has heat dissipation? To keep the iMac cool and happy, Apple's included six temperature sensors, three fans, and two gigantic heat sinks. To put the massive size of the heat sinks in perspective, check out the relative size of the USB ports on the bottom left of the board. Notice the PRAM battery on the logic board (circular silver disc) for storing date and time when the power is disconnected. When changing the battery be careful to not to force the plastic top that holds the battery into place.
  • I can has heat dissipation? To keep the iMac cool and happy, Apple's included six temperature sensors, three fans, and two gigantic heat sinks.
  • To put the massive size of the heat sinks in perspective, check out the relative size of the USB ports on the bottom left of the board.
  • Notice the PRAM battery on the logic board (circular silver disc) for storing date and time when the power is disconnected. When changing the battery be careful to not to force the plastic top that holds the battery into place.
  • The processor is socketed, but there's a "Warranty void if removed" sticker above one of the heat sink's screws.
  • Our 3.06 GHz E7600 Core 2 Duo processor is a LGA 775 Socket T CPU. There are some Core 2 Quad chips that use the same socket, but we don't know if they would work. The i5 and i7 quad-cores included in the high-end 27" iMac use a different socket, LGA 1156 Socket H.
Hier Übersetzung einfügen
