Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 9
Use a plastic spudger to open the three plastic connectors and slide the ribbon cables out, no force should be used. Disconnect the three other connectors from the logic board, using a spudger if necessary.
  • Use a plastic spudger to open the three plastic connectors and slide the ribbon cables out, no force should be used.
  • Disconnect the three other connectors from the logic board, using a spudger if necessary.
  • Remove the four 6 mm T9 Torx screws from the corners of the logic board.
  • The board can now safely be removed from the CD-ROM drive.
Hier Übersetzung einfügen
