Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 11
It is advisable to grab an old CD and push it half way into the CD-ROM drive until it is visible through the hole marked in the first picture. This will prevent the part that has to be removed in this step to fall down into the unit, with the risk of damaging the laser. The metal plate slides forward as shown in the first picture. Use a pair of tweezers to very carefully slide forward and then lift up and remove the metal plate together with the white plastic disk.
Removing disk clamp
  • It is advisable to grab an old CD and push it half way into the CD-ROM drive until it is visible through the hole marked in the first picture. This will prevent the part that has to be removed in this step to fall down into the unit, with the risk of damaging the laser.
  • The metal plate slides forward as shown in the first picture.
  • Use a pair of tweezers to very carefully slide forward and then lift up and remove the metal plate together with the white plastic disk.
  • I did not take the unit apart beyond this level, taking it apart any further might offset the calibration of the laser and damage the unit.
Hier Übersetzung einfügen
