Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Englisch
Deutsch
Schritt 19
Use a spudger to disconnect the connector from the board. Flip over the front panel and pull off the rubber knob of the rotary push button. Remove the 11 mm nut with a pair of pliers or a socket wrench if you have one that is long enough.
Removing the rotary push buttons
  • Use a spudger to disconnect the connector from the board.
  • Flip over the front panel and pull off the rubber knob of the rotary push button.
  • Remove the 11 mm nut with a pair of pliers or a socket wrench if you have one that is long enough.
Hier Übersetzung einfügen
