Zum Hauptinhalt wechseln
Englisch
Deutsch
2. Schritt
Locate the two bolts that secure the inlet to the engine block and remove them. Use a 12 mm socket and ratchet. Pull the water inlet off the engine block. Due to age, the inlet may stick to the block. Place pressure on the side of the inlet to break the seal, if needed.
  • Locate the two bolts that secure the inlet to the engine block and remove them. Use a 12 mm socket and ratchet. Pull the water inlet off the engine block. Due to age, the inlet may stick to the block. Place pressure on the side of the inlet to break the seal, if needed.
Hier Übersetzung einfügen
