Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2 übersetzen
2. Schritt
With the home bar out of the way, gently pry up the display using the opening tools. There is another ribbon cable attached to the bottom of the LCD. Be careful not to damage either of the connectors when removing. Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
  • With the home bar out of the way, gently pry up the display using the opening tools.
  • There is another ribbon cable attached to the bottom of the LCD. Be careful not to damage either of the connectors when removing.
  • Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
  • Gently lift out the display.
Hier Übersetzung einfügen
