Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Step 1
Remove two 4.5 mm Phillips screws from the left-hand side of the PSP. Slide off the left trigger along with the plastic bracket underneath. Carefully pry off left trigger button using opening tools.
  • Remove two 4.5 mm Phillips screws from the left-hand side of the PSP.
  • Slide off the left trigger along with the plastic bracket underneath.
  • Carefully pry off left trigger button using opening tools.
  • The button is adhered to the body. It can be re-adhered with hot glue after being pried-up, if necessary.
Hier Übersetzung einfügen
