Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
2. Schritt
Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly. If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
  • Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
  • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
Hier Übersetzung einfügen
